Machine Vision
How to convert C++ in labview?
Hi
I have a visual studio c++ application. May I transfer to labview. I use one dll file. I was trying to wrap all functions using shared library wizard but without success. Could someone help?
(4,950 Views)
If you build your C++ code as a DLL, you can call it with LabVIEW using the Call Library node, that allows to make DLL calls from LabVIEW.
(4,939 Views)
@tiho wrote:
Hi
maybe this will help you:
https://decibel.ni.com/content/blogs/kl3m3n
There are a couple of examples on how to create a .dll from c++ source code using OpenCV. There are also some examples on how to call such a .dll in Labview.
K
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(4,934 Views)
