Machine Vision
How to define a rectangle programmatically to use as a RIO
I'm analysing a video and would like the option to either define a RIO by clicking and dragging on the video window or by using a default region. I've manage to do the click and drag but I can't set the rectangle to be the to corner of the video. Video resolutions change between files so I need to use the info from the width and height to define the coordinates . These values then need to be passed to the IMAQ convert rectangle to RIO. The problem is I cant write to the function in the rectangle data type. I tried a standard cluster of the 5 elements which are in the rectangle data type but this doesn't work. How do I do this? The picture shows the code I have.
thanks
Stephen
Labview 14.0, Labview 12.0
CLAD
Mechanical Engineering Student
(5,861 Views)
Covert the cluster to array of 4 elements then it will work for you
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(5,842 Views)
Accepted by Stephen1995
use this example to solve yuor problem
(5,835 Views)
The above statement has to be reversed to make the concept workROI Selection.PNG
(5,813 Views)
I don't get why you are using Build cluster array instead of Bundle for cluster.
-The input to Rectangle to ROI is cluster of five elements, not cluster of array of five elements.
-no need of making array then converting to cluter.
-Just use bundle the five numbers using https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/functions/bundle.html
-let me know if that helps.
uday
(5,803 Views)
Yes this worked. thanks
CLAD
(5,798 Views)
