Hello.
May I ask about the triggered acquisition?
I'm doing test with pci-1428 and xcl-v500.
First, I test it the grab mode well.
Second, I test about the triggered ring mode, but it doesn't do it.
My test situation is that I use the strobe amp,
so, that is operate the lamp and trigger to the board (RTSI 0) periodically (10Hz)
but, the blank image is appeared periodically.
I use the normal mode, shutter speed 1/1000 in the camera file and the triggered ring in the Labview example.
I got the camera file at the camera advisor and I modify the file using the camera file generator.
I saw the camera support file,
there is a trigger test using trigger mode2,
so I also test using trigger mode 2 but I failed.
so, please tell me how to do the triggered ring.
I wonder how to set the camera parameter, additional connect using horose 12 pin( HD,VD)
and what kind of the LabVIEW example I use.
I ask the matrox board user about this,
he tell me he test the triggered ring using trigger mode1.
and set the board clock and camera clock equally
but I think the control is different each other(Matrox, NI).
I wonder which mode can method become better method between mode 1, 2 ?
My test environment is
LabVIEW 7.1, NI-IMAQ 3.1.3, Camera file generator is 2.0
Board is PCI-1428,
Camera is XCL-V500
I attached the my modified camera file and camera file support document.
I wish quick response, Thanks
