Machine Vision
How to draw an arc in the image window?
Now I try to draw an arc in the image window, but when I try to use IMAQ Overlay Arc.vi, it need Bounding Rectangle that made a problem because the arc I draw has a big size whose bounding rectangle was out of the image window. What should I do?
(2,852 Views)
Bounding rectangle parameters will allow you to enter larger values than your image size as well as negative numbers in order to position your arc properly.
I hope this helps!
Yusuf C.
Applications Engineering
(2,852 Views)
