Machine Vision
How to embed C200 webcam activex in labview?
I have LOGITECH C200 webcam. I want to embed C200 picture preview ActiveX control in LabView. Is there anyone can help me? What library do I need? Where can I find?
Thank you.
(4,510 Views)
Do you simply want to use the webcam in LabVIEW or do you really want to embed an activeX control in LabVIEW? If you embed an ActiveX control, that will completely depend on whether logitech has enabled activeX support. If you simply want to display images, I would take a look at the IMAQdx driver from Vision Acquisition Software assuming the camera is DirectShow compliant.
-Zach
(4,494 Views)
I wanna embed the video preview in LabVIEW and take & save picture every ten minutes. What should I do?
Is IMAQ driver free? where can I get that driver?
Thank's for helping..
(4,485 Views)
The IMAQdx driver is not free and will require a license. You can however download it from here and get a 30 day free trial when you install it:
http://search.ni.com/nisearch/app/main/p/ap/tech/pg/1/sn/ssnav:sup,catnav:du,n8:7820/lang/en
-Zach
Message Edited by iZACHdx on 04-23-2010 12:55 PM
(4,473 Views)
