10-17-2007 03:52 AM
10-18-2007 07:20 AM
10-18-2007 07:50 AM
Hi Elmar,
thanks for your reply. The problem I got is that there is not a ccd chip with RGB-Bayer pattern, but with an Gr-Mg-Cy-Ye Bayer pattern. The "normal" pattern should be no problem.
You can find it in the manual, at pages 133 and 134:
The "NI White Balance Utility" offers only RGB patterns.
Greetings
Juergen
10-18-2007 08:07 AM
10-18-2007 09:41 AM
Hi Elmar,
I was afraid of that. So I have to implement an algorithm to get the RGB colors myself.
Thank you for your efforts.
Perhaps there´s someone out there who knows/has a solution.
Greetings
Juergen
08-29-2008 09:28 AM
Hello Juergen,
I have a problem like you did with the same camera model. Did you succeed in the implematation of the algorithm to get the RGB color?
Any help would be greatly appreciated.
José.
08-30-2008 01:18 PM
Most cameras include the option to do the Bayer decoding on the camera and transmit back a color image. It looks like that is your only option in this case.
Bruce
09-01-2008 04:28 AM
Hello José,
I´m very sorry, but I can´t give you a solution. We changed the camera models. We now use the Guppy F036C, which has a rgb-bayer pattern and is fully supported by NI software.
It has been more efficient for us than writing an adaption for this camera.
I hope you´ll find a solution for your problem. If you have, perhaps you can let me now how you solved it.
Greetings,
Juergen
09-01-2008 04:56 AM
Hello Juergen,
If I find a solution I'll tell you.
Thank you for the help,
José.
