Machine Vision
How to get serial communication working with a SONY XCL-X700 together with a PCI 1426
Dear Forum,
We have a serious problem getting the SONY XCL-X700 camera going together with the PCI-1426. Even when using the MAX-software we are not able to establish serial connection.
When we try this we get the following message:
Error 0xBFF60092
The requested serial termination string was not found in the return buffer.
It seems like the .icd-file of the Sony XCL-X700 does not implement the correct serial protocol.
If we change in the .icd the following:
TermChars (OK\n\r) -> TermChars (\x06)
Then it seemed that the "Termination string" was solved, but now we got the following error message:
Error 0xBFF60093
The serial read did not complete within the specified timeout period.
The used baudrates were 38400 and 19200.
These are the first lines of the used .icd-file:
CameraFile (5.50) {
   Manufacturer (Sony)
   Model (XCL-X700)
   CreationDate (20050216102252)
Is there somebody who can help us with this issue?
Kind regards,
Laogong
(4,561 Views)
I have the same problem with the PCIe-1427 with the XCL-X700.  Did you get this issue resolved
(4,238 Views)
I Have exactly the same Problem and will call NI now ... will post if i know more
(4,067 Views)
After calling NI i got the following link, to an japanese site:
... i can not read the text, but the files are the correct camera drivers for the MAX. (also for the XCL-V500 )
So far all seems to work now.
Message Edited by brezelbert on 07-17-2008 05:24 AM
(4,050 Views)
