Machine Vision
How to increase the image hight limite (nbre of lines) for a linear camera (Basler ruL1024-36gm)
I am using a Basler ruL1024-36gm linear camera and I need to acquire an image having up to 6000 lines. Unfortunatly, the image hight is limited to 4095 lines (in MAX or VBAI)
Is there  a way to increase this limit?
Thank you for your reply!
(VAS: March 2011
VBAI 2010)
(3,140 Views)
This limitation is impossed by the camera and may be due to memory limitations on the camera. You could talk with Basler to see if there are any options.
Hope this helps,
Brad
(3,132 Views)
