Machine Vision
How to load a .png Pattern Image
I am developing programs in VC++ 2005 to perform a simple pattern matching. Here is what I would like to achieve
Program A:
1. read a jpg image from file.
2. learn the pattern.
3. save the pattern image as .png.
4. close A
Program B:
1. load the .png pattern image. (no learning is performed)
2. load the target image.
3. perform pattern matching.
The problem I am encounting is that when B is executed, step 1 never works. The error message was "not an image". I am just wondering what may cause this error. Thank you very much.
(3,388 Views)
dzwang -
Could you post your code that is returning that error?  That would be helpful in diagnosing the problem.
Thanks!
Greg Stoll
Vision R&D
Greg Stoll
LabVIEW R&D
(3,366 Views)
