Machine Vision
image_struct
When i complie and execute the example " easy acquire  "  (c:\program files\National instruments\Vision\Example\Msvc\Easy acquire)
I want to know the image structure defined in <nivision.h>
typedef struct Image_struct Image
but there is no way to get the definition or declaration about image struct from camera.
I want to use OpenCV with pci-1410 board in c++
Is there solutions to get the image information, definition, definition ???
Please let me know~!!      T.T
thanks for reading
(3,854 Views)
prince -
The easiest way to get a representation of the image you can use with external toolkits is to call imaqImageToArray() to get the pixel data.  Be sure to call imaqDispose() on the result after you're done with it to avoid memory leaks.  You can call imaqGetImageInfo() to get information about the image.  More information about these function calls are available in the  Function Reference Help.
Greg Stoll
Vision R&D
Greg Stoll
LabVIEW R&D
(3,828 Views)
