10-12-2008 09:21 PM - edited 10-12-2008 09:21 PM
Solved! Go to Solution.
10-13-2008 08:03 AM - edited 10-13-2008 08:04 AM
Hi, skyover,
Just create rotated rectangle ROI, then overlay ROI insted of rectangle:
Andrey.
10-13-2008 08:59 AM
10-14-2008 01:22 AM
10-31-2008 08:56 AM
Hi in a simular vein to this,
i am trying to insert a small jpeg [which can be converted] into a larger jepg image [as a temperature scale]
I seem to be having trouble with the conversion and its trying to get me to use an odd format as an input which confuses me.
Basically on the same pallatte as the overlay is overlay bmp, but i'm at a loss as to how to get it to read the data in, and set its possition.
Please help!!
the code above will work for the example i need it for, the image i'd like to inser tis attached.
cheers!!
