Machine Vision
How to overlay a part of image with inclined retangle
I know IMAQ Overlay Retangle.vi can overlay a part of image with retangle ,but i want overlay it with inclined retangle (see as overlay.jpg), How can I solve this?
thanks
帖子被skyover在 10-12-2008 09:21 PM
时编辑过了
(4,338 Views)
Accepted by topic author skyover
Hi, skyover,
Just create rotated rectangle ROI, then overlay ROI insted of rectangle:
Andrey.
Message Edited by Andrey Dmitriev on 10-13-2008 03:04 PM
(4,313 Views)
You can also use overlay multiple lines. and feed an array of points in the order you want them to be over layed.
(4,301 Views)
thank you
(4,286 Views)
Hi in a simular vein to this,
i am trying to insert a small jpeg [which can be converted] into a larger jepg image [as a temperature scale]
I seem to be having trouble with the conversion and its trying to get me to use an odd format as an input which confuses me.
Basically on the same pallatte as the overlay is overlay bmp, but i'm at a loss as to how to get it to read the data in, and set its possition.
Please help!!
the code above will work for the example i need it for, the image i'd like to inser tis attached.
cheers!!
(4,180 Views)
