Machine Vision
How to physically connect multiple cameras to the PCI-1410
I have a PCI-1410 card which I would like to connect to muliple cameras. From the searches I've done it's unclear what is the best way to physically do this. Should I use the IMAQ-A6822 box? Is there a cable available with 4 BNCs on one end and a 68-pin connector on the other? (I think there was such a cable, that has been discontinued.)
Note: there is a specific topic on connecting multiple cameras: http://digital.ni.com/public.nsf/allkb/FF3C5C368E34A12286256AC6004BD844 but it does not mention physical connections at all.
Thanks you,
Itay
(3,054 Views)
Hi Itay,
The IMAQ-A6822 box is the recommended accessory to break the signals out and prototype your application. It has not been discontinued.
We had other break out cables, but they're much simpler and did not expose all the signals you need for your application.
What most customers do, once their prototype is working, is contact a cabling company to create a custom cable for deployment of the system.
-Christophe
(3,035 Views)
