Machine Vision
Is there a memory leak in Algorithms.Rake function?
I am using NI Vision 2009 with VS2008. There appears to be about an 80kb memory leak when using the Algorithms.Rake function. It gets worse if I try to use it in a separate thread. Has anyone else discovered this?
My code:
Dim lineReport As New FitLineReport
Dim returnValue As Boolean = False
Dim roi As New Roi
Dim roiCenter As New PointContour(453.5, 240)
Dim roiRotatedRect As New RotatedRectangleContour(roiCenter, 321, 478, 0)
roi.Add(roiRotatedRect)
'find straight edge
Dim rakeOptions As New EdgeOptions
With rakeOptions
.ColumnProcessingMode = ColumnProcessingMode.Median
.InterpolationType = InterpolationMethod.Bilinear
.KernelSize = 37
.MinimumThreshold = 128
.Polarity = EdgePolaritySearchMode.Rising
.Width = 1
End With
Dim rakeReport As RakeReport = Algorithms.Rake(imgVwr.Image, roi, RakeDirection.RightToLeft, EdgeProcess.First, 13, rakeOptions)
(4,905 Views)
Hello Steve,
There has been a similar report on this. Let me investigate this further for you.
Andy Chang
(4,877 Views)
The previous CAR was closed but it was not well documented on the workaround or any fixes. I've reopened the CAR and will get in touch with our R&D personnel.
Andy Chang
(4,876 Views)
Can you post the CAR#?
(4,863 Views)
CAR#222280
The RD team is informed of this and there may be a fix in the future. The workaround for this is, since rake is looking for an edge, using SimpleEdge() instead. A way to improve execution time using Simple Edge() would be to increase the space between the Rake's.
Andy Chang
(4,823 Views)
