Machine Vision
How to save 16 bit images from high frame rate camera in real-time
Hi Shiju,
This thread is quite old, I think you'd get more traffic on a new thread.  Also, we recommend keeping it to one issue per thread so it helps other users search the forums.
Marti C
NI Medical
Message 11 of 13
(1,088 Views)
You should watch this link: Saving Images with a Real Time Camera . I had problems with the rate frame at saving images, it was reduced due to the time needed to save every image. If you can keep the same frame rate with your camera, you may post it.
Impossible is nothing
Message 12 of 13
(1,062 Views)
Just another factor to consider...
If you are recording a lot of images in individual files in Windows it can get a bit unmanageable as Windows doesn't like too many files in a folder. It takes forever to open the folder in Explorer, to list the folder contents in LabVIEW, etc.
Cheers,
Mike
Message 13 of 13
(1,045 Views)
