Machine Vision
How to turn off IMAQdx periodically sending a "Discovery Ping" to 255.255.255.255?
IMAQdx seems to search for GigE cameras by periodically (about every second) sending a "Discovery Ping" to 255.255.255.255.
As my vision system does not use any GigE camera (only FireWire) I would like to get rid of these "Discovery Pings".
Is there a recommended way to accomplish this?
Regards, Guenter
Message 1 of 8
(6,285 Views)
Accepted by topic author GuenterMueller
Hi Guenter,
On Windows there is not currently a simple way to disable GigE Vision support in the installer. However, you can disable the automatic discovery mechanism with the following registry key:
You should be able to save the following as a .reg file and import it:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\niimaqdxk\Parameters]
"DiscoveryTimeout"=dword:00000000
Eric
Message 2 of 8
(6,277 Views)
Thanks Eric. I will try this tomorrow. BTW: Do I loose GigE support this way? Or is it just the support to discover "yet unknown" GigE devices? Guenter
Message 3 of 8
(6,266 Views)
You would lose automatic discovery of GigE Vision cameras. You can still manually discover cameras by running the Discover Ethernet Cameras function/VI.
Eric
Message 4 of 8
(6,261 Views)
Ok, Eric. I see, that it works. (No need to wait until tomorrow.)
Thanks, Guenter
Message 5 of 8
(6,257 Views)
I have a couple of questions in regard to this.
If use the registry key as described is there a way to manually detect the camera when you are using the Measurement and Automation Explorer?
Is there anyway to restrict the discovery ping to a specific network card? We typically install a second NIC card and use non-routable IP addresses for that NIC and camera and it would be nice to limit the discovery ping to that card.
Later
Walleye
Message 6 of 8
(5,896 Views)
Hi Eric,
i cant see the link
Message 7 of 8
(4,409 Views)
As this is an old thread I don't know if you can still rely on this information.
However, if a registry key doesn't exist, you can create it ...
Message 8 of 8
(4,406 Views)
