Machine Vision
How to use the IMAQ rval = imgGrab(SESSION_ID sid, void** bufAddr, uInt32 syncOnVB)function?
Please explain the format of "bufAddr" variable?
And how to convert this data to *.bmp format?
(3,913 Views)
Hi arm2arm;
First, are you sure the function prototype says that the variable "bufAddr" is a handle? In the documentation the function prototype looks like:
imgGrab(SESSION_ID sid, void* bufAddr, uInt32 syncOnVB)
Declare a variable as:
Int8* bufAddr = NULL;
When set to NULL, IMAQ will allocate the necessary memory. Then, when using the function, just cast the variable as void.
Use the function imgSessionSaveBufferEx() to save the image as a .bmp file.
Regards;
Enrique
www.vartortech.com
(3,913 Views)
Hi again;
I did some tests and, for some reason, my program do not want to compile because the function is actually asking for a void** handle instead of a pointer. In order to work, you may want to declare a variable as in the previous answer:
and cast it in the function as:
(void **)&bufAddr
Enrique
www.vartortech.com
(3,913 Views)
