Machine Vision
How to use the Watershed Transform VI?
I want to use  Watershed Transform to separate the touching particles like the image,could you give me a example VI show me how to use it,thank you very much!
(4,207 Views)
Try eroding the image.
Message Edited by muks on 06-10-2010 02:14 PM
(4,203 Views)
But the problem is you have to erode and dilate the image seprately since you have black dots and white dots.
(4,200 Views)
I erode  the image and use IMAQ Threshold get the binary image, after that I want to use Watershed Transform VI,but I don't know how to use it ,could you give me a example VI ?
(4,194 Views)
I tried watershed in vision assistant but it didnt seperate the circles as expected. You can try the same from vision assistant.
(4,187 Views)
I tried.but the output  image like this ,I want to get a binary image.图像 1.png
(4,184 Views)
