10-11-2005 08:17 AM
10-11-2005 11:14 PM
Vision Assitant may take some additional copies of your image for processing which might slows down your PC. I guess the performance meter will run mulitple times internally and give you the average processing time. So i guess the time 1.5S may be right and the 15 minutes is because of slower PC performance at the time or memory overflow than RAM capacity. The particle analysis vis are not time bounded, the processing time might vary depends on the number of particle.
logic
