Machine Vision
I installed a PCI-1426 board and have a mikrotron-1302 camera buty does not work - cannot snap pictures in MAX
I have installed a PCI-1426 frame grabber board on a new machine. I also downloaded the .icd file for the camera I have (a Mikrotron 1302 camera) and put it in the directory with all the other icds.  The camera can be accessed from the Mikrotron camera configuration software, and I am also able to select it from MAX under the devices-PCI1426-img0 tab so that I know that MAX is at least finding the .icd, but then when I try to snap an image I get an error:
"0xBFFF800B The session you requested failed to execute.  Check that the user dll are on the system."
Any ideas anyone.  Thanks.
(3,404 Views)
Dear experiment_juggler
What versions of NI-IMAQ and MAX do you have installed? If you do not have the most recent versions, I would recommend updating.
Vision Acquisition Software Download Page
http://joule.ni.com/nidu/cds/view/p/id/960/lang/en
Do you have administrative rights on your computer? If not, this could be the source of the problem.
If the above two suggestions do not work, try running a simple example program from LabVIEW or whichever programming language you are using. Does your setup work correctly with the example?
Hope this helps,
~Nate
(3,377 Views)
Nate, thanks for the reply.
I do have administrator rights on the computer.
I tried to install the latest versions from the link you sent.  I was unable to install it because I got the message that there were unsupported versions of: NI system components, NI VISA, NI PXI and NI IMAQ.  I guess I will try to unistall everything and install it all from scratch.  Does that make sense?
(3,369 Views)
I believe a re-install of your software should fix the problem. If not, please let me know and we can try to troubleshoot further.
Best Regards,
~Nate
(3,356 Views)
