Machine Vision
I want to pattern matching with 10bit image file
I have a 10bit camera, maker:UNIQ, type:UC-610
I used vision builder, and acquire 10 bit image then
try pattern matching analysis but don't run it.
how can I do it ?
(3,045 Views)
The pattern matching algorithms don't work on anything other than 8 bit images. You will need to convert your images to 8 bit before using pattern matching.
A word of warning: The default settings for pattern matching in Vision Builder 6.1 are quite different from the settings for VB 6.0. You can get very different results in the two versions. These settings can't be changed in VB, but can be changed in LabVIEW.
Bruce
Bruce Ammons
Ammons Engineering
(3,045 Views)
