Machine Vision
IEEE 1394 1.5.3 Update missing Files
I have downloaded ver 1.5.3 of the IEEE 1394 driver to update my system form ver 1.5. When I try to install the driver on a NI 1455 CVS it says I am missing chknvs.dll on my local computer. What am I missing?
(3,331 Views)
Hello.
The location of the file that you are referencing should be the following:
C:\Program Files\National Instruments\RT Images\CommonVision
Basically, it is a resource file for the Real-Time component of the driver.
If this file is missing, or even the directory itself, it is just an installation issue. When you run the NI-IMAQ for 1394 installation (1.5.2), there should be an option to add real time support. If this option is not checked, then this component may not be present.
To fix your problem, I would recommend uninstalling the IMAQ for 1394 driver, installing the driver version 1.5.2 ensuring that you select Custom install, and that the 'NI 1450 Series Support' is selected to be installed. Then, install the 1.5.3 patch and you should b
e good to go!
Colin C.
Applications Engineering
Colin Christofferson
Community Web Marketing
Blog
(3,331 Views)
