Machine Vision
ImgMemUnlock.vi is generating errors
I am looking for a reason I would be getting this message. LabView: An exception occurred within the external code called by Call Library Node. This might have corrupted LabVIEW's memory. Save any work to a new location and restart LabView.
VI "name of vi" was stopped at node 0xEA8 of subVI "imgMemUnlock.vi"
Thanks for any help I receive.
(2,946 Views)
Hello.
I have looked into your issue and have not been able to locate anything conclusive right away. As such, I believe we need a little bit of information about your application (i.e. what IMAQ VIs are you using, if you are doing a ring/sequence how many buffers, etc.)
The VI to which you are referring is not called by nearly all of the common NI-IMAQ VIs, imgMemLock.vi is called by the IMAQ Start VI, but the imgMemUnlock is not very common. Also, let us know what version of the driver you are using.
A couple of suggestions:
1. Uninstall and re-install the driver. The current version of NI-IMAQ is 3.0. I recommend upgrading if you are not using it.
2. Try running some of the example VIs and see if you get any issues from them.
Colin C.
Applications Engineering
Colin Christofferson
Community Web Marketing
Blog
(2,946 Views)
