Machine Vision
IEEE 1394 for IMAQ Deployment Issue
I have IMAQ Vision 6.0 and the IMAQ Vision Deployment Engine for Vision 6.0 , which installs the Vision 6 Runtime Engine on my target , but i also use IEEE 1394 for IMAQ in my application and the IMAQ Visiion Deployment engine doesn't seem to install/support that. Do I have to manually install IEEE 1394 for IMAQ onto my target in order to have my Application not be broken ? Also , what are the licensing requirements for Deploying Applications which contain IEEE 1394 for IMAQ vi's. I am using the Labview 6.1 Professional Development system. Thanks.
(3,386 Views)
You do need to install IMAQ for IEEE 1394 separately. I believe you need to purchase a license for each computer you will be using it on. You should call NI or your local sales rep to get the details.
Bruce
Bruce Ammons
Ammons Engineering
(3,386 Views)
