Machine Vision
IMAQ 12-bit/16bit monochrome buffer format - bitwise justification
I'm new to using the IMAQ software and PCI-1424 card, in addition to not
having access to an operational (IMAQ) system yet, so please be patient
with me.
I need to know how IMAQ "justifies" 12-bit data within the 16-bit buffer
format. ie LSB: 2047 -> 2047 (0x7FF), or MSB: 2047 -> 32752 (0x7FF0) ?.
regards,
Richard Rudek.
MicroDek, Sydney, Australia.
(3,087 Views)
Richard,
By your definition, it would be the LSB format. The higher bits are always zero. The values remain the same. It is just like converting a U8 to I16. Note that 16 bit images are signed (I16) not unsigned (U16).
Bruce
Bruce Ammons
Ammons Engineering
(3,087 Views)
On Tue, 6 Aug 2002 22:47:37 -0500 (CDT), Bruce Ammons
wrote:
>Richard,
>(U16).
Thank you.
regards,
Richard Rudek.
(3,087 Views)
