Machine Vision
IMAQ AVI2 Read Frame Error
Hi
I get the following error when I try to extract all of the frames of an avi file. Error -1074396010 occurred at IMAQ AVI2 Read Frame
I have it in a while loop to execute reading and writing the frames and then save them as .jpegs.
Any insight or help is appreciated.
(5,878 Views)
Accepted by goldfronts1
solved it myself. thanks
(5,845 Views)
I am having a similar error, how did you end up fixing it?
(4,250 Views)
Can you post how you fixed it? Labview is linking to this post
(2,623 Views)
