Machine Vision
IMAQ Advanced Pattern Matching Functions
What do they do ?
Is there a description available.
(3,609 Views)
Rikske-
Take a look at chapter 12 in the Vision Concepts Manual:
http://digital.ni.com/manuals.nsf/webAdvsearch/A84F8C4BB40374C5862569A700520CC0?OpenDocument&vid=niwc&node=132100_US
You will also want to read through chapter 5 of the IMAQ Vision for LabVIEW User Manual:
http://digital.ni.com/manuals.nsf/webAdvsearch/FD6C94779E009AC28625698C005F71FD?OpenDocument&vid=niwc&node=132100_US
These should give you a good idea of what the functions do.
-Julie
(3,609 Views)
Thanks for the info, but........
I'm working with IMAQ 6.1. In my concepts manual there is no information about the functions
-IMAQ Advanced Setup Learn Pattern 2
-IMAQ Advanced Setup Match Pattern 2
-IMAQ Refine Matches
In the manual they only talk about the standard pattern matching functions.
It seems that in the new IMAQ 7.0 help file there is much more info. Maybe these functions are described in there ?
Greetings
(3,609 Views)
