Machine Vision
IMAQ Block Statistics - Minimal and Maximal Value Giving 0
Guys - can someone please test. Mean and Standard deviation give good numbers.  Min and Max are both showing zero (0).
(5,175 Views)
Accepted by DonRoth
Make the Boolean Compute Min/Max? to True to get the Min and Max values.
uday
(5,161 Views)
Yes, that is it.  Thank you.  It makes no sense to me that min/max would not be calculated as part of a block statistics analysis.  Have no idea why such a switch would exist, therefore did not even consider this possibility.  Perhaps the calculation is more rapid without including min/max calculation.
Sincerely,
Don
(5,154 Views)
