Machine Vision
IMAQ Block Statistics - Minimal and Maximal Value Giving 0
Guys - can someone please test. Mean and Standard deviation give good numbers.  Min and Max are both showing zero (0).
(5,171 Views)
Accepted by topic author DonRoth
Make the Boolean Compute Min/Max? to True to get the Min and Max values.
uday
(5,157 Views)
Yes, that is it.  Thank you.  It makes no sense to me that min/max would not be calculated as part of a block statistics analysis.  Have no idea why such a switch would exist, therefore did not even consider this possibility.  Perhaps the calculation is more rapid without including min/max calculation.
Sincerely,
Don
(5,150 Views)
