Hello Beko,
so if you need the mm you should use the calibration function. You are able to correct the image or also not. It depends on the application. For example you take a picture from a bottel. And you want measure the distance of the lable on the bottle. If you dont correct the image you measure wrong because the lable on the bottel is normaly distorted
. So you have to correct the image. Please look at the Concept Manual in Chapter 3 if you need more information.
Start/Programme/National Instruments/Vision/Documentation/Ni Vision/Concept Manual
Kind regards,
Elmar
