Machine Vision
IMAQ PCI-1407 basic image digitizer register test failed
I have a NI IMAQ PCI-1407 card with the b/w video camera connected to it. Trying to snap an image from NI MAX results in an error "can't lock on video source". Moreover, the card does not pass the "basic image digitizer register test" when diagnosed from MAX.
I know that it is not a hardware problem since identical functional card gives the same error.
Any clue about what is the reason for failure?
regards,
Danielis
(3,222 Views)
This question is already taken care of by direct contact with NI. In the end a driver instalation problem caused this to happen.
RikP
Application Engineering
Rik Prins, CLA, CLED
Software Development Engineer
(3,212 Views)
