Machine Vision
IMAQ imgGrabSetup error: Not enough memory to perform the operation
The question is about the function imgGrabSetup, the Imaq Lib. What does it do actually, and how does it work?
 I need that knowledge to solve my problem. I have two different programs. In which one is not working because of an error:
“Non Fatal run-Time error: Function imgGrabSetup return value==-1074397181 (0xbff60003) not enough memory to perform the operation”
The thing is,
on both the Sid is the same, and what´s more, it takes only confirmation about the acquisition.  Both progs have different structure,  working one has "standard grab" structure, and the other one, well has “mine one…” but I´m working on global structure and variables. I have checked that every one of them is ok, and it has it correct value until the moment of the not working imgGrabsetup function where everything just "stops".
Can someone explain me this please?
(3,702 Views)
Which language do you use?
LABVIEW, Labwindows or VS.NET?
Waleed El-Badry MSc.,MCPD, ISTQB Certified Tester
Assistant Lecturer
Mechatronics Department
Faculty of Engineering
Misr University for Science & Technology
View Waleed El-Badry's profile on LinkedIn
(3,670 Views)
Hi Deusto,
 here you are a forum thread that tackles the same issue:
http://forums.ni.com/ni/board/message?board.id=200&message.id=11496&requireLogin=False
Beside, you can find tips to improve memory allocation in this knowledge base:
http://zone.ni.com/devzone/cda/tut/p/id/3490
Regards.
(3,614 Views)
