Machine Vision
IMAQ mouse pointer changes from arrow to finger/hand when on executable
I am using LabVIEW 7.0 and Vision 7.0. When developing the source code, the mouse pointer used to select points on the Image Window is an arrow. When an executable is created, the mouse pointer become a hand with a finger. How do I change the mouse pointer back to an arrow for the executable? Thanks for your help in advance.
(2,947 Views)
This is an issue that National Instruments R&D is currently investigating. Unfortunately there is no known work-around right now.
(2,947 Views)
