Machine Vision
IMAQdx setting exposure manually works wrong
i am using MAX Version 4.6.0f1 and want to integrate our camera as NI-IMAQdx Device.
It works good except, when i am changing exposure manually.
When i write 0.125 (seconds) , the MAX should send -3  (2exp(-3)==0.125) to the
IAMCameraControl-Interface of my Capture-Filter.
But i get -2 from the Max software. Is this a bug?
Thanks in advance.
(4,153 Views)
Accepted by net_dev
Hi net_dev,
On some quick investigation, it appears you are correct. I believe IMAQdx is incorrectly using a natural log function instead of base 2 log.
I have filed CAR 200481 for tracking this bug if you need to reference it. Note that this bug only affects DirectShow (usually USB) cameras---no other cameras types use this interface.
Eric
(4,139 Views)
This bug still seems to be present, at least in the software version I am using (Labview 2009, VDM 2009). Is there a workaround, or a hope of a fix? At the moment I am having to use separate software just to control exposure...
(3,347 Views)
This was reported fixed in IMAQdx 3.6 back in 2010.
Eric
(3,341 Views)
Thank you for the reply. I did not realise until now that later versions of VAS were compatible with Labview 2009 (http://digital.ni.com/public.nsf/allkb/808663CDBB335A9E86257D430001A980).
(3,334 Views)
