Machine Vision
ISC-1772C ethernet direct connection issue
When I am setting up the Ethernet connection between PC and ISC-1772C, use a router in between works but directly connect the Ethernet cable to my PC's LAN port and assign an IP address to the smart camera won't work (I followed the manual, Thinkpad P50 and Windows 7). is this a firmware issue? or I am missing something.
Thanks for the help.
(2,587 Views)
Accepted by zrs5532
The manual mentions that if you have trouble detecting your smart camera, you should set your firewall to open the TCP/UDP ports used by the NI 177x Smart Camera and the host machine. (http://www.ni.com/pdf/manuals/373491a.pdf)
Could you check?
(2,548 Views)
