02-08-2022 12:58 AM
The image of part to be inspected using camera and product in perpendicular direction.
1. Basler Camera :Basler acA2440-20gm
| Sensor Format | 2/3'' | |
| Sensor Type | CMOS | |
| Sensor Size | 8.4 mm x 7.1 mm | |
| Resolution (HxV) | 2448 px x 2048 px | |
| Resolution | 5 MP | |
| Pixel Size (H x V) | 3.45 µm x 3.45 µm | |
| Frame Rate | 23 fps | |
| Mono/Color | Mono |
2. Lense : Computar M1214-MP2 (f=12mm F1.4)
But the image seems to be not correct towards the right end as if dilated some perspective / parallax/distortion. The image is finally used to do geometric pattern matching.
Please help to fix it or any other additional set up used.
02-08-2022 09:41 AM
This looks like a case where I would seriously consider a telecentric lens. You are going to have some parallax errors with the current lens no matter what you do. If you move the camera back and use a longer focal length lens, it would reduce but not eliminate the parallax. A telecentric lens is the only way to completely eliminate parallax.
Bruce
02-08-2022
10:58 AM
- last edited on
07-27-2026
11:22 AM
by
Content Cleaner
Bruce is correct that telecentric lens is the best. But the other option of moving the camera away from the object and using longer focal lens will help a lot. Should be sufficient for geometric pattern finder.
Try to use f = 45 or similar.
Other option is to use image calibration to correct the image before you do the processing.
Good luck
Amit
