Machine Vision
Image capturing by IR camera with BNC cable using video card
Hello friends,
I am using IR camera with BNC cable. This BNC cable is connected to PC by "Conexant Bt PCI WDM video capture card". So i am little bit confused that how can i use that camera in LabVIEW ?
I am using LabVIEW 8.5.1, LV RT 8.5 , Vision Acquisition's software 8.5 with Vision Development module 8.5
camera - IR camera with BNC cable output
PCI card -  Conexant Bt PCI WDM video capture card
so can anyone explain how can i capture image using this camera?
(3,881 Views)
Hey,
You will have to contact the manufacturer of this PCI Card for a driver.
The NI Vision Acquisition Software just works with NI framegrabbers, and for sure firewire, usb, gigE and IP Interfaces.
Christian
(3,724 Views)
The PCI card with the Conexant chipset is very likely using a driver which should support DirectShow. Assuming your card has proper drivers installed, you have a fairly good likelyhood that it will work with the DirectShow support included with IMAQdx.
 Eric
(3,722 Views)
