Machine Vision
Imaq Debayer Pattern
Hello everyone,
the "IMAQ Bayer to RGB" VI has the option to use GB, GR, BG or RG Bayer patterns.
How do they relate to the "standard" Bayer patterns: BGGR, RGBG,GRBG,or RGGB ?
thanks for your replies.
Andreas
(2,209 Views)
Accepted by Andreas111
I believe they are the same, but just the first two letters.  It is easy to figure out the last two letters from the first two letters since the greens are always opposite corners.  Also, I think your RGBG pattern should be GBRG.
Bruce
Bruce Ammons
Ammons Engineering
(2,179 Views)
