Machine Vision
Imaq Image type mismatch older instance Image data type
I've made a program using LabView 6i with Imaq Vision, upgrading to LabView 7 (with Imaq Vision 7) i get the following error message:
" Wire: this type mismatch may be caused by an older instance of the image data type  -
This type mismatch may be caused by an older instance of the Image data type.  To fix it, simply replace the instance with the IMAQ Image.ctl type definition in the Image Controls menu palette."
I've experienced this problem with several VIs as : IMAQ ROI profile; IMAQ Overlay Points and so on.
What can i do? Do i have to replace the instance of the image data type in every of these instruments?
Thanks for your help
(4,447 Views)
I am having the same mismatch problem as above.. however I cant find the convert vi wold this solution still be applicable in Labview 9?
(4,103 Views)
