02-04-2010 09:14 AM
The Camera Advisor takes me to a file for the L401k which is single tap. I'm using the dual tap L402k on a 1428 card. Has anyone produced a suitable icd file that they'd be willing to share?
Solved! Go to Solution.
02-05-2010 12:48 PM
You can either download Camera File Generator to create the camera file for it OR you may modify the camera file for L401k to have two taps by adding
Tap (2) {
Position (Adjacent)
Start (Left, Top)
after Tap(0)
02-05-2010 12:53 PM
Thanks Andy, as you suggested, I opened up the icd file and added the second tap.
Thank you!
