Machine Vision
Imaq dx driver for USB Camera getting hanged in Stop and Close Acquisition
Dear Sir/Madam,
I am using USB Camera model number FL3-U3-88S2C-C from point grey. It is acquring the image but when i am trying to close the session by IMAQdx Stop Acquisition and IMAQdx Close camera it is getting hanged. It is not coming out from that function.
Please suggest me some solution regarding this problem.
(5,589 Views)
Dear Ajeet,
Is your camera in trigger mode?.
Silver_Shaper | CLD
(5,582 Views)
Yes, My camera is in trigger mode and timeout is 1000Ms
(5,576 Views)
Ajeet,
Actually your program waits for the trigger to exit from the current loop. Do this press STOP button and give one trigger and see.
Silver_Shaper | CLD
(5,572 Views)
You are right, it is waiting for trigger but after timeout it should exit automatically. this is happening for other camera but only with this camera it is not happening. Trigger handled by other machine so i can't give trigger at the time of machine stop.
(5,570 Views)
Better you contact camera manufacturer for the support.
Silver_Shaper | CLD
(5,557 Views)
Have you updated this camera's firmware to the new version that supports the USB3 Vision protcol? This will allow it to use IMAQdx's internal driver rather than the DirectShow interface to Point Grey's driver (which I suspect you are using).
Eric
(5,549 Views)
