Machine Vision
Imaq video out display mode -- widescreen resolution
I am trying to output the image from an EVS-1463RT to a monitor. The IMAQ RT Video Out VI works as expected, however the matching IMAQ Video Out Display Mode VI uses an enumerated display resolution, of which there are only 6 possibilities from 640x480 to 1920x1440. I would like to specify a resolution that matches my widescreen monitor. Is there any way to do so?
Thanks.
(4,122 Views)
Accepted by topic author tarask
Sorry, the current image display mechanism on the EVS is based on the VESA video standard, which only support a certain set of fixed resolutions (and no widescreen variants).
Eric
(4,115 Views)
Do you know if there is any other way to output the desired resolution from the RT system without using these VIs?
(4,104 Views)
Unfortunately not.
Eric
(4,101 Views)
