Machine Vision
Imaqdx is not update value when save ni max
Hi all,
I'm using Vision Development Module 2020, I am having problem with Imaqdx Grab2.vi, it does not load attributes when I Grab, although I successfully saved it with NI Max (as shown above, I saved the camera resolution in NI MAX and saved it as 640x480 but when Grab resolution 2592x1944). Is this a bug of the 2020 version or not?
If not please show me how to fix this problem.
Sincerely
(1,428 Views)
Hello Vuka,
I noticed that you are changing attributes through a .txt file.
Although this should be a way to change the attributes, I recommend you change the camera attributes by going to NI MAX and following the steps mentioned here:
Accessing Camera's Attributes in NI MAX
If you have already solved the issue another way, kindly share the solution to help future users 🙂
Cheers,
(1,147 Views)
