Machine Vision
Questions about using vision builder API other than labview
Hello i have 2 questions regarding the vision builder API that cannot find response to:
1- I understand that .net wrapper is no longer supported on the lastest version(2020), but its stated on the web and on the installer that there is some C/C++ API. I cannot find any documentation about this feature at all on the included documentation, all the included API examples are for labview so i am totally lost.
2-I have checked the vision builder examples on github of the .net wrapper but the vision builder example has references to the NationalInstruments.Vision.Common.dll, that as far as i know is part of "NI Vision Development Module" . This module needs a diferent license than vision builder, does that mean that is intended for you to have both a license of vision builder and the vision development module to acces the vision builder API? or can be this dll be used without the vision development license?
I have checked that the only use of this dll(NationalInstruments.Vision.Common.dll) is for accessing and displaying the images, so i guess i could recode that part myself if the image format is documented anywhere (haven't find anything so far).
If anyone is curious on the why: I need to use vision builder, yes is a requirement. And since we have experienced coders(that have never used labiew) and is a big project with several integrations(yes, they would be probably posible on labview but more time consuming) using labview is not an option.
I am also checking the option on running directly vision builder in run mode and use the integrated comunications(i think it supports modbus) as an short of api, but is a less clean solution, and only a last resort.
Any help/ideas are welcome 🙂
(1,753 Views)
Hey Peter,
As I understood you want to create APIs using C/C++ to use them in LabVIEW, and you need documentation for how to do that?
(1,634 Views)
