Machine Vision
In Pattern matching angle remains Zero even if the rotated
in example find pattern matching the angle remaings zero .. even the image is rotated
(5,948 Views)
are you using rotation invariant method (also for template calibration)?
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(5,940 Views)
hi Klemen,
        1.    in vision assistant if i enable Rotate and search . the angle is able to find ..
        2.   and also i have to give proper template (template created by vision assistant) ..
So . I need to help regarding template creation for pattern matching . Do YOU HAVE ANY vi CODE THAT CREATE AND SAVE TEMPLATE FROM Live Camera Image (Grab ) ..
 (Note : in example file of vision i found some code in create template . that one is single image snap and also in event Structure..)
(5,931 Views)
Accepted by topic author SaranVenkateshS
see a simple example in the attachment (saved for LV 2012).
Yes, you could also use event based structure.
Hope this helps.
K
(5,921 Views)
hi Klemen,,
              Thanks a lot for you kind response ..
              I am going to work with vision and motion based project (GigE) Camera ..
              How to frame the code for Vision and motion ?
              How to do Camera Calibration for (1mm x 1mm)?  ( In website i have seen some Calibrationn Grid Image )
(5,912 Views)
hi Klemen,
       for finding angle (rotation invariant method) . whats the angle range i should specify
(5,900 Views)
depends on the degree of rotation you expect. Selecting a wider interval of angles, the detection speed will also decrease.
K
(5,887 Views)
