Machine Vision
vbai acquire several images
Hi
we are working with VBAI 2012 and we want to acquire several images as fast as possible one after the other to decide which is the best for the inspection. Is there any possibility to take e.g. 5 images one after the other or do I have to call the acquire image control five times?
thanks
Oliver
Message 1 of 8
(6,786 Views)
Accepted by topic author OZI
Why not use Acquire Continuous images and use number of buffers as 5 as required?
uday
Message 2 of 8
(6,781 Views)
Dear Uday,
that easy 😄 Great, thanks a lot
greetings
Oliver
Message 3 of 8
(6,778 Views)
you will still need to call the Avq step five times to get five different images. You could call your state that has the acquisition in a loop. also in that state score your image and if it has the highest score transition to a state where you update an image variable with the current image. Initialize the high score to zero before the first iteration. After your state with acquisition and scoring has run five times transition to your processing state and the first step can be a Select Image that gets the image variable with the best score.
Hope this helps
Brad
Message 4 of 8
(6,773 Views)
Hello Brad,
that means it does not work with continuous acquire and five buffers? I have to call the acquisition five times?
I tried this but the acquisition was "very slow". A loop will also not be "high speed" because I have to add 10-20ms for the state on each loop
The parts I want to inspect are moving in front of the camera and I want to find the picture which fits the best when the part is moving
greetings
Oliver
Message 5 of 8
(6,770 Views)
You can configure the acquisition for continuous with 5 buffers and if you choose "Get Every Image" mode, the images returned by the step will be 5 consecutive images acquired by the camera. So even the camera only took 10ms to acquire each image and it takes you 50ms to do any processing and call the acquire image step again, they will consecutive if you can avoid overflowing your buffer.
The first section talks about the different acquisition modes.
Hope this helps,
Brad
Message 6 of 8
(6,768 Views)
Hello Brad,
I think the Continuous - every picture comes close to what I want. On every part I need 3, 4, 5 pictures to find the best position and the rest of the cycle i can do the evaluation. I will try that out and will give feedback
thanks
Oliver
Message 7 of 8
(6,766 Views)
Hello Brad
I tried out the Continuous - Get every picture mode but I only get one picture back.
To avoid misunderstandings, I am using a Basler camera, could this be the reason that it is not working?
thx
Oliver
Message 8 of 8
(6,596 Views)
