Machine Vision
How to get minimal Image Display VI
I'm building a GUI for a multi camera ROV (Underwater Robot), and I want to include several live image feeds in the display.
I can get the feeds to work, but I seem to be stuck using one of the two "Display Image" VI's on the Vision Pallet.
These have a range of additional features that I don't want, and cant seem to turn completely off.
eg:
-There is a "raised" area with border around the image that is just taking up real-estate.  I can't seem to reduce this to zero. (I've tried the new and classic vi)
-There is a tool pallet which I don't want.  I have various "preview" windows that just need to be dumb displays.  The tools are not only unnecessary, but a problem is someone clicks on the image by accident.
So.. Bottom line I'd like just a dumb minimal Image display window VI that I can feed with an IMAQ Image.ctl wire, and that accepts no user input.
Is such a thing available?
Phil.
Get a life? This IS my life!
(3,930 Views)
Accepted by topic author Philbot
You can turn off scrollbars, tool palette, as well as Image Info string. Then just resize visible area over boders:
See attachment
Andrey.
(3,919 Views)
Excellent... The thing that I had missed was the ability to resize the window within the indicator frame.
Thanks a heap !!
Phil.
(3,899 Views)
I just want to ask what underwater camera are you using. I am currently researching on coral detection and classification and I am looking for an underwater camera that is compatible with labview. Any suggestions?
Your response will be very much appreciated.
Mark
(3,590 Views)
