Machine Vision
How to get minimal Image Display VI
I'm building a GUI for a multi camera ROV (Underwater Robot), and I want to include several live image feeds in the display.
I can get the feeds to work, but I seem to be stuck using one of the two "Display Image" VI's on the Vision Pallet.
These have a range of additional features that I don't want, and cant seem to turn completely off.
eg:
-There is a "raised" area with border around the image that is just taking up real-estate.  I can't seem to reduce this to zero. (I've tried the new and classic vi)
-There is a tool pallet which I don't want.  I have various "preview" windows that just need to be dumb displays.  The tools are not only unnecessary, but a problem is someone clicks on the image by accident.
So.. Bottom line I'd like just a dumb minimal Image display window VI that I can feed with an IMAQ Image.ctl wire, and that accepts no user input.
Is such a thing available?
Phil.
Get a life? This IS my life!
(3,808 Views)
Accepted by Philbot
You can turn off scrollbars, tool palette, as well as Image Info string. Then just resize visible area over boders:
See attachment
Andrey.
(3,797 Views)
Excellent... The thing that I had missed was the ability to resize the window within the indicator frame.
Thanks a heap !!
Phil.
(3,777 Views)
I just want to ask what underwater camera are you using. I am currently researching on coral detection and classification and I am looking for an underwater camera that is compatible with labview. Any suggestions?
Your response will be very much appreciated.
Mark
(3,468 Views)
