Machine Vision
Interpolation
In Edge detection VI has the interpolation is mentioned. I want know the interpolation types and how it will work.If anybody knows please explain.
(4,276 Views)
which kind of edge detection you means?
based on their algorithm that most of them use averaging data you can get subpixel data for edge
(4,247 Views)
Accepted by Panjimar
There are mainly three types of interpolation used in IMAQ Find Edge VI or any other edge vi.
- From VI help https://www.ni.com/docs/en-US/bundle/ni-vision-labview-api-ref/page/imaqvision/imaq_find_edge.html
Zero Order (0)
Rounds to the nearest integral edge location
Bilinear (1)
Uses bilinear interpolation to compute the edge location
Bilinear Fixed (4)
(Default) Uses the fixed-point computation of bilinear interpolation to determine the edge location
-Check the SubPixel Accuracy Topic for how the interpolation works in here https://www.ni.com/docs/en-US/bundle/ni-vision/page/concepts-17.html
-And this wiki on Bilinear interpolation can help https://en.wikipedia.org/wiki/Bilinear_interpolation#Application_in_image_processing
uday
(4,238 Views)
