Machine Vision
Invalid Coordinate System??
Hey,
I have made a very simple script in the vision assistant tool - when I run it within the tool, everything is fine - but when I put it in my VI, I get an "Invalid Coordinate System" error.
What I am trying to do is to first have a pattern matching to locate my object, then I want to set a coordinate system based on that, and use that for a reference for the rest of the script - but no matter what I try, the "set coordinate system" outputs "NaN" - eventhough the pattern matching is working perfectly.
any ideas?
Message 1 of 14
(9,500 Views)
Try by creating a labVIEW vi from vision assistant.
Message 2 of 14
(9,496 Views)
you mean: right click, "open front panel" - right?
this is what I got - no change
Message 3 of 14
(9,493 Views)
I meant creating vi from vi vision assistant
Message 4 of 14
(9,480 Views)
Accepted by topic author Ehlert
Hi Henrik
I've run into this behavior as well. This is a bug in LabVIEW 2013 it should be corrected in LabVIEW 2014.
In the mean time we have created a patch that you can use to solve this.
If you replace the attached file with that one that is already there in this folder:
<LabVIEW>\vi.lib\vision
and restart LabVIEW you issue should be solved.
Best Regards
Anders Rohde | CLD | Platinum Applications Engineer | National Instruments Denmark
Message 5 of 14
(9,474 Views)
it works!
thanks Anders
Message 6 of 14
(9,467 Views)
ohh, and btw - the patch also speeds up the script by at least a factor 50 - was actually a bit worried since is was extremly slow when running on the target - the proformance meter claims that it should be able to run in less than 50 ms, but before this patch it took seconds...
Message 7 of 14
(9,465 Views)
Thanks for the update Henrik - I'm glad it solved the issue.
Message 8 of 14
(9,463 Views)
Hi rohde,
Can you post the car number?
Message 9 of 14
(9,459 Views)
Hi Muks
CAR #441410
Best Regards
Anders Rohde
Message 10 of 14
(9,456 Views)
